12 years agoCan I use EPCQ32 with Cyclone III?
Hello, I mistakenly used an EPCS16 (8-pin SOIC) in my design with a Cyclone III EP3C120. Active serial has been working but if I use more than half the chip then my program will probably not fit ...
12 years agoI think I figured it out, I can use the EPCQ32 but I have to select "Disable EPCS ID Check" under advanced when converting the programming file. I don't know why that was not the default for my selections but that's ok, life is good...
