18 years agoCan I use 3.3V VCCIO for LVDS receiving in stratix ii FPGA?
hello, I need to connect an ADC to the stratix ii FPGA by LVDS signals. The max signal frequency is 600MHz and the LVDS power of ADC side is 3.3V. Can I connect the VCCIO pins of the FPGA's IO bank5 ...
18 years agoTo do that checking, I make a simple dummy design that takes all the inputs into a really wide AND gate.
That AND Gate then drives the enable on a really long counter that drives the outputs. If I have multiple clocks in the design, then I just make multiple of these "designs". Run it through the tools, and check to see that there are NO assignment voilations. 10 minutes max!
