8 years agoCan I produce 4 MHz from a 10 MHz input?
Hi All, I have a Cyclone IV board. Can I produce 4 MHz from a 10 MHz input? I am totally new to this field. I can produce 4 MHz using the 50 MHz on-board clock using PLL. But it seems GPIO ca...
8 years ago --- Quote Start --- It's true that PLLs have dedicated clock inputs, these give the best performance, but I was able to assign a GPIO as a PLL input on my Cyclone V (not Cyclone IV) device using the global_clock buffer IP. Maybe this is feasible on the Cyclone IV as well? --- Quote End --- Interestingly Cyclone V device handbooks says it's no feasible: --- Quote Start --- Internally-generated GCLKs, RCLKs, or PCLKs cannot drive the Cyclone V PLLs. The input clock to the PLL has to come from dedicated clock input pins, PLL-fed GCLKs, or PLL-fed RCLKs. --- Quote End --- I guess, the Cyclone III/IV constraint is enforced by the design software on purpose. Dropping it for Cyclone V might be just a bug.
