15 years agoCan i deserialize LVDS using DCFIFO ?
Hi, I am wondering if i could deserialize a LVDS signal using a DCFIFO block ? I've tried numerous method, but no success. Michael
15 years ago --- Quote Start --- Technically, isn't changing 1 bit to 16 bits possible? --- Quote End --- Only if the underlying dual-ported RAM supports writes at 16-bit and reads at 1-bit. Even if it doesn't, you can easily write a state machine to read in 16 x 1-bit values, and then write it to one port of a RAM at 16-bits. The reader on the other side would also read 16-bits. From the top-level, this component would look like a 1-bit to 16-bit deserializer. This however only works if the clock rate of your 1-bit data can be dealt with by the FPGA. The whole point on the hard-IP LVDS SERDES is that they operate at much higher frequency than the fabric logic elements. --- Quote Start --- I've tried altlvds_rx, it could only go up to 10 bits. --- Quote End --- So, that is all they need to do. Take for example a 1Gbps data stream (which is near the fastest the LVDS SERDES can run). If you operate the SERDES in 1:8 mode, then inside the FPGA, the parallel data is 1GHz/8 = 125MHz. If you want 16-bits or 32-bits inside the FPGA, just do that demultiplexing using logic elements. Cheers, Dave
