SYiwe's avatar
SYiwe
7 years ago
Can I create a 32768*64 Dual-Port RAM with Logic Cells in Arria10 SoC?
I try to create a Dual-Port RAM in Arria10 with Logic Cell(LC), the depth of RAM is 32768 and the width of RAM is 64.
After "Analysis & Elaboration", the following errors appear:
Error (287078): Assertion error: Current device family (Arria 10) does not support more than 2048 memory words unless the USE_EAB parameter is not turned off
Error (12152): Can't elaborate user hierarchy "test_top:u_test_top|fft_sink:u_fft_sink|RAM_32K_64_LC_2PORT:RAM0_32K_64_LC_2PORT|RAM_32K_64_LC_2PORT_ram_2port_181_jdrgbli:ram_2port_0|altdpram:altdpram_component"
I already set "RAM Block type" to "LCs", and I believe the USE_EAB is on, that means not turned off, but I still can not generate a RAM more than 2048 words.
Any suggestions?
Thanks, regards.
1 Reply
