Toby__5
2 years agoCan I connect 3.3V devices to cyclone10GX?
I want to connect an IC with an I/O voltage of 3.3V to cyclone10GX. However, the datasheet says it only supports up to 3V. Does this mean I can't connect directly to 3.3V devices? If you can't conne...
AqidAyman_Altera
2 years agoHi,
For the DC input voltage for Cyclone 10 GX, they supported up to 3.3V for 3V I/O. Pin voltage should not be externally pulled higher than the maximum value.
Please be noted the VCCIO is for the I/O buffers power supply.
