Toby__5
2 years agoCan I connect 3.3V devices to cyclone10GX?
I want to connect an IC with an I/O voltage of 3.3V to cyclone10GX. However, the datasheet says it only supports up to 3V. Does this mean I can't connect directly to 3.3V devices? If you can't conne...
FvM
2 years agoDatasheet specifies 3.3 V input voltage in recommended operating conditions plus overvoltage margin. 3.3V driver supply is o.k. if you avoid overshoot by placing suitable serial termination for longer lines.
Toby__5
2 years agoThank you for your reply.
The device I want to check is the 10GX, not the Cyclone10LP.
It seems that the VCCIO conditions for Cyclone 10GX only include 3.0V (2.85V to 3.15V).
Does Vccio of the 3 V I/O bank mean that I can connect external I/O devices with a 3.3V level while keeping it at 3.0V?
Datasheet:Cyclone® 10 GX Device Datasheet 683828 | 2022.02.14
Thankyou.
- FvM2 years ago
Yes. I was quoting input voltage spec of Cyclone 10 GX datasheet.
