York_tsang
1 year agoCan CXL host force device to response with data when sending SnpData to device through CXL.cache?
According to CXL spec, a device doesn't need to return data if the device doesn't response with Res*Fwd* in d2h response channel. But as a host, can I force the device to return data?
RongY_altera
Contributor
1 year agoHi,
From host side, it's unlikely to do so since the system environment should follow the spec.
Say the CXL action you described is posted, and you find a way to change it to be non-posted, what will happen?
Rong
