18 years agoCan conditional builds be performed in VHDL?
I'm relatively new to VHDL and am looking for a way to perform conditional builds. I'm aware of the `ifdef that is available in Verilog, but am trying to find a comperable method in VHDL.
18 years agoOliver:
I'm not familiar with AHDL, but I suspect that the "PARAMETER" statement you refer to is the same as VHDL's "generic". I've used that before, but for parameterizing between two levels only. I suspect that there would need to be a precedence rule when passing a parameter between multiple levels. In the case of my recent experiment with generic/generate, I used that to cut down on editing between simulation vs. system build versions. The previous engineer for this project would comment out and uncomment portions of code each time. I modified the lower level entity with a generic to default as a simulation version by generating it's own signals normally passed in on input ports from the higher level entity. The higher level entity that instantiates the lower overrides the lower level entities’ generic default by passing in a value to use the system build version of code.
