10 years agoCan an FPGA partially fail? (EPM7128SLI84-10)
Hi All, I have a production run of 110 plug in modules that each use a single EPM7128SLI84-10, two of these devices are suspected of failing as the modules show exactly the same fault in that 8...
10 years ago --- Quote Start --- From my understanding - an FPGA should just either work or not work. If theres something failing then I, like Kaz, assume it's a timing problem, or could it be other parts failed on the board? There is no way to "lock out" a failed part of the FPGA as you would have no way to know which cells have failed, and I would assume more cells would just fail after. Can you not just try a replacement/swapped board? --- Quote End --- Hi I've assumed that with large areas of silicon you can't easily send the +5V or 0V around everywhere from a single connection without serious voltage drops - hence the need for several 5V and 0V connections. I don't know however if these 'assumed' sections of the silicon are connected - hence we checked that all the 5V connections were intact externally - but they may have fused internally. All conjecture, but the logic behind the thought that perhaps one of these siloicon areas had failed. The module is quite simple - the only other part we can't check easily is a microcontroller, but currently the main suspect is the FPGA - we need to check this with the programming software now as we are scratching our heads! I'll report back when we get to program or at least attempt to! Cheers James
