Can’t find generation for .hex in Quartus 22.1
This isn't possible. A .hex for an on-chip RAM or ROM is created manually as a separate file (File menu -> New) and then incorporated into a .sof or other programming file. You can't extract a .hex from an existing programming file.
Convert programming file is only used to do just that: convert an existing programming file from one format to another.
- Jcole2 years ago
My end goal is to write an external FPGA image file in the flash then use it with the Remote Update System to reprogram new FPGA versions. I have the RSU system working, and I can communicate with the Flash, but just trying to test out writing the SOF/POF data to the flash. I wanted to use a ROM to hold the data during testing phase, but not sure what's the best method for testing the flash writing.
