17 years agoCalculating the number of gates I need..??
I wonder how I can calculate the number of gates I will need for an application. For example, if I need a 16Bit-Counter, how much gates will this need? Which device will fit this application?
17 years agoTrue as Harald says about Migration.
But you may decide your pins early and may not need any extra pins later but just extra internal resource. For this end some devices are manufactured as a set of different sizes but with same footprint, the largest device will have the full set of pins, smaller devices will be subset of the main pinout. Then you can start buying largest device of a set and then migrate down if necessary provided you have used the correct subset of pins on your board.
