16 years ago
ByteBlasterII JTAG chain problem detected
Hi
I´m trying to program a EP3C5E144C8N FPGA in JTAG mode using a ByteBlasterII cable. The pins are connected as indicated in the JTAG configuration of a single device using a download cable (Fig 10.24 of the Cyclone III handbook). All the power suplies used have been measured in the device and are OK.
When I test the JTAG chain integrity the QuartusII return the messages:
-No device detected
-The TDO connection to the dowload cable migth be shorted to GND or is an open circuit
-The TCK and TMS connections to the last device migth have problem.
I used the IDCODE iteration and tested all the signals in the blaster connector and the TDO signal is always in 0.01V when I think that this signal must change around 2.5V when programming.
Any idea?
Thank in advance
    Your question can be answered very different.
    - There's always a certain risk of damaging electronic devices by ESD. Some reports say, that 50 % of unspecific device faults are caused by ESD events. It's recommended to use protection equipment not only in production but also in development and prototyping.
    - It's unlikely, that a particular device has been damaged by ESD in an usual lab enviroment.
    - More likely damaging mechanisms are overheating during solder and supply overvoltages
    - Potentially dangerous equipment are isolated SMPS without protective ground connection, either supplying a mobile computer or a development kit
