15 years agoByteBlaster 5V parallel port
I have a byteblaster 5V which connect to te PC by the parallel port. Can I use it to programm a MAXII CPLD with it (changing the 5V signals by 3.3v signals of course and if necessary). A...
15 years agoThere are three ByteBlaster models in use:
- Byteblaster (5V only, using a 74LS244 buffer) - Byteblaster MV (3.3/5, using a 74HC244 buffer) - ByteBlaster II (1.8 - 5 V, using a discrete transistor and IC interface) In addition, ByteBlaster II supports AS serial programming.
