16 years agoBuilding crossGcc / gcc tools for Windows?
I see on the nioswiki that there are instructions for building the crossGcc toolchain on Linux. My toolflow is currently in Windows so I was hoping to compile crossGcc for Windows. I started wi...
16 years agoJust in case someone tries to compile crossGcc under cygwin in the future (yes I know cygwin builds are not my first choice either), here's what I had to change to get it to compile:
In the file binutils/ltconfig, beginning at line 791: while test "X"`$CONFIG_SHELL $0 --fallback-echo "X$testring" 2>/dev/null`
= "XX$testring" &&
new_result=`expr "X$testring" : ".*" 2>&1` &&
lt_cv_sys_max_cmd_len=$new_result &&
test $i != 17# 1/2 MB should be enough
do
i=`expr $i + 1`
testring=$testring$testring
doneneeds to be changed to: while test "X"`$CONFIG_SHELL $0 --fallback-echo "X$testring" 2>/dev/null`
= "XX$testring" &&
test $i != 11# PREVENT CYGWIN HANG, hopefully 11 iterations is still enough
do
i=`expr $i + 1`
done
