11 years agoBuffered Programming for NOR Parallel Flash and Ingrating with NIOS BSP
Hello everyone,
I am working on a NIOS board integrated with NOR parallel flash. The Altera BSP has a CFI driver for the flash, however it has support for Word programming and the buffered programming method. The Buffered programming speeds up the flash writing process by 10X. I have the code written for buffered programming. All I need to know is how to make it work i,,e 1) How do i integration this buffPgm_flash() function alone in to the HAL/Flash Driver and not lose the code after ever generate BSP command? Need steps to achieve this? Any impact/modifications to be done on sopc? 2) Does altera Provides the a standard driver code with the Buffer programming support? 3) Can this be implemented as an application code by pulling the CFI data structures from BSP? If not why? Regards ChandramohanNo RepliesBe the first to reply
