18 years agoBRAM implementation in Altera Quartus
Does anyone here know how to implement BRAM in Altera Quartus?? The inferred BRAM in my design isn't working in my synthesizer and i get logic instead of BRAM. Thats why compilation of my design fail...
18 years agoThis is the generated VHDL file of the asyncram block:
ENTITY altsyncram0 IS PORT ( address_a : IN STD_LOGIC_VECTOR (11 DOWNTO 0); address_b : IN STD_LOGIC_VECTOR (11 DOWNTO 0); clock : IN STD_LOGIC ; data_a : IN STD_LOGIC_VECTOR (31 DOWNTO 0); data_b : IN STD_LOGIC_VECTOR (31 DOWNTO 0); wren_a : IN STD_LOGIC := '1'; wren_b : IN STD_LOGIC := '1'; q_a : OUT STD_LOGIC_VECTOR (31 DOWNTO 0); q_b : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ); END altsyncram0; ARCHITECTURE SYN OF altsyncram0 IS SIGNAL sub_wire0 : STD_LOGIC_VECTOR (31 DOWNTO 0); SIGNAL sub_wire1 : STD_LOGIC_VECTOR (31 DOWNTO 0); COMPONENT altsyncram GENERIC ( address_aclr_a : STRING; address_aclr_b : STRING; address_reg_b : STRING; indata_aclr_a : STRING; indata_aclr_b : STRING; indata_reg_b : STRING; init_file : STRING; intended_device_family : STRING; lpm_type : STRING; numwords_a : NATURAL; numwords_b : NATURAL; operation_mode : STRING; outdata_aclr_a : STRING; outdata_aclr_b : STRING; outdata_reg_a : STRING; outdata_reg_b : STRING; power_up_uninitialized : STRING; read_during_write_mode_mixed_ports : STRING; widthad_a : NATURAL; widthad_b : NATURAL; width_a : NATURAL; width_b : NATURAL; width_byteena_a : NATURAL; width_byteena_b : NATURAL; wrcontrol_aclr_a : STRING; wrcontrol_aclr_b : STRING; wrcontrol_wraddress_reg_b : STRING ); PORT ( wren_a : IN STD_LOGIC ; clock0 : IN STD_LOGIC ; wren_b : IN STD_LOGIC ; address_a : IN STD_LOGIC_VECTOR (11 DOWNTO 0); address_b : IN STD_LOGIC_VECTOR (11 DOWNTO 0); q_a : OUT STD_LOGIC_VECTOR (31 DOWNTO 0); q_b : OUT STD_LOGIC_VECTOR (31 DOWNTO 0); data_a : IN STD_LOGIC_VECTOR (31 DOWNTO 0); data_b : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ); END COMPONENT; BEGIN q_a <= sub_wire0(31 DOWNTO 0); q_b <= sub_wire1(31 DOWNTO 0); altsyncram_component : altsyncram GENERIC MAP ( address_aclr_a => "NONE", address_aclr_b => "NONE", address_reg_b => "CLOCK0", indata_aclr_a => "NONE", indata_aclr_b => "NONE", indata_reg_b => "CLOCK0", init_file => "F:/hello.mif", intended_device_family => "Cyclone", lpm_type => "altsyncram", numwords_a => 4096, numwords_b => 4096, operation_mode => "BIDIR_DUAL_PORT", outdata_aclr_a => "NONE", outdata_aclr_b => "NONE", outdata_reg_a => "CLOCK0", outdata_reg_b => "CLOCK0", power_up_uninitialized => "FALSE", read_during_write_mode_mixed_ports => "DONT_CARE", widthad_a => 12, widthad_b => 12, width_a => 32, width_b => 32, width_byteena_a => 1, width_byteena_b => 1, wrcontrol_aclr_a => "NONE", wrcontrol_aclr_b => "NONE", wrcontrol_wraddress_reg_b => "CLOCK0" ) PORT MAP ( wren_a => wren_a, clock0 => clock, wren_b => wren_b, address_a => address_a, address_b => address_b, data_a => data_a, data_b => data_b, q_a => sub_wire0, q_b => sub_wire1 ); END SYN; First of all, i have created the behaviour of the block: process (clk) begin if (clk'event and clk = '1') then if (wren_a = '1') and (wren_b = '1') and (address_a=address) and (data_a/=data_b) then report "write collision" severity failure; end if; if (wren_a = '1') then ram(to_integer(unsigned(address_a))) := data_a; q_a <= data_a; else q_a <= ram(to_integer(unsigned(address_a))); end if; if (wren_a = '1') then ram(to_integer(unsigned(address_b))) := data_b; q_b <= data_b; else q_b <= ram(to_integer(unsigned(address_b))); end if; end if; end process; Now i'm having difficulty on where i should put this code in generated vhdl from asyncram. anyone has idea?
