11 years agoBooting Cyclone 4 with STM32F407
Hello! Iam so sorry but i didnt find any solution or whitepaper with circuit diagram where they are booting FPGA with ARM CPU. Does anyone know anything about this option? Is able to use classi...
11 years ago --- Quote Start --- Could you please check the circuit below if is correct? --- Quote End --- Since you cannot guarantee the state of the nCONFIG pin when the ST micro boots, you should have a pull-down, so that the FPGA is disabled until the micro enables it. CONF_DONE and nSTATUS should have external pull-ups (or you can enable pull-ups on your micro pins). You should have a source termination on your DCLK signal (back at the micro pin). You need to double-check that the FPGA configuration pin voltages are compatible with your microcontroller (if they are all 3.3V, then they will be fine). Make sure your design also includes a breakout of the FPGA JTAG signals to a standard 10-pin header. It will make debugging of your design simpler :) Cheers, Dave
