13 years agoblock ram area equivalent in logic elements , Cyclone iv
Hi, I have several designs synthesized on cyclone iv fpga and all of them use only 2 resources : Logic elements and Block Rams (M9k). I want to compare the area consumption of the designs , but...
13 years agoThe synthesisor will also auto generate code into syncrams without you realising, or pack common logic together that you didnt realise was common. Shift registers are a common example. You can stop the synthesisor doing this via settings or instance assignments in the qpf, but usually this may only be neccesary for tight timing requirements.
