15 years agoblock diagram from VHD file
Just wondering if there is a way to generate a block diagram from just a VHD file? I am looking at an old vhd file for the max7000S:EPM7256SQC208 CPLD, also using version 10 web edition of quartus 2.
I was able to find the RTL viewer and get it to work as also found an associated project file.
it looks like (create symbol file from current file) is not enabled, any ideas? The VHDL file is around 7 years old.
thanks for the responses, just wondering is RTL viewer part of the quartus 2 version 10 web edition?
yes.
File -> create/update -> symbol file from current file. Be aware, it only likes certain things on the port map. Edit - this just creates you a block to put in another graphic file. For a schematic view of your code, you need the RTL viewer. - Altera_Forum
I think RTL viewer may help you.
