15 years agoblock diagram from VHD file
Just wondering if there is a way to generate a block diagram from just a VHD file? I am looking at an old vhd file for the max7000S:EPM7256SQC208 CPLD, also using version 10 web edition of quartus 2...
15 years agoyes.
File -> create/update -> symbol file from current file. Be aware, it only likes certain things on the port map. Edit - this just creates you a block to put in another graphic file. For a schematic view of your code, you need the RTL viewer.
