18 years agoBit extending when adding
Hello, I'm trying to add an signed std_logic_vector(21 downto 0) with a std_logic (unsigned) using the vhdl operator "+". I'm using the "IEEE.std_logic_signed.all" library . I just assumed that...
18 years agoThere are a few quirks with numeric_std which take a bit of getting used to if you've been using std_logic_signed.
E.g. if you're incrementing a std_logic_vector by integer 1 with std_logic_signed:my_vector <= my_vector + 1; if you use numeric_std then you have to do a bit of casting: my_vector <= std_logic_vector( signed(my_vector) + 1 ); At first I found this a bit laborious but once I got used to it I actually found that it made the code clearer and easier to mix signed and unsigned operations in the same source file. Good luck.
