15 years agoBinary format for Stratix IV Image in a NOR CFI Flash?
My application requires that a host system can write a new FPGA image into an on board Nor Flash (CFI intel P30 style 16 bit flash). Without using a JTAG pod, or Quartus Programmer. Instead...
13 years agoAwesome! Thanks shuckc, exactly what I needed.
I spent some time trying to figure out why when I convert a sof to rbf directly using the quartus_cpf command i.e. quartus_cpf -c <input_sof_file> <output_rbf_file> the rbf file would not match what I saw in the flash (i.e. it lacks the "PFL/.pof packetisation" headers you mentioned). However, your method of sof->pof->hexout->rbf matches what I see in the flash. It is unfortunate that Altera provides different ways to generate a rbf file from an sof, each with different results. I wish Altera would make these things more obvious instead of searching through forum posts and knowledgebase tickets for obscure details.
