18 years agoBig numbers of input, output ??
hello everyone, I am a newbie. After trying in 2 days, I can't do a thing to solve the following problem. My mp3 player design requires to transfer 576 integer number ( 576x32 bit ) among ...
18 years ago --- Quote Start --- Unfortunately, it is not very useful. There are many SV features implemented, but not mentioned in the documentation. And viceversa, some features are documented as implemented, but they are really not. The only conclusive way I found, is to just try. And the Quartus documentation doesn't cover ModelSim at all. Quartus does support packed arrays on ports, it is the Altera version of ModelSim the one that doesn't. --- Quote End --- You are completely right. package definition; typedef struct packed { logic a; logic b; } fraction; typedef struct packed{ logic [3:0] scfsi; fraction [1:0] gr; } kkk; endpackage Compiling above example, I got this error: "error (10168): systemverilog declaration error at aaa.sv(11): prefix for packed array type does not refer to a packable type". Although fraction is declared as an packed structure. Quartus 8.0 seems not to support packed union inside an packed structure and packed array of packed structures as well.
