16 years ago
Bidirectional SPI switch?
This is a complex problem which I am very unsure of, the basic idea is that I want code that switches between 3 SPIs.
I was startled when I noticed the statement that I was about to write
A_SCLK <= C_SCLK
C_SCLK <= A_SCLK
both are true, but this would induce registers, all I want is a wire connection.
-- The idea is that choose either A or B is exclusively
-- connected to C
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity bidir_SPI_switch is
    port(
        A_SCLK, B_SCLK, C_SCLK        :    INOUT STD_LOGIC;
        A_SOMI, B_SOMI, C_SOMI        :    INOUT STD_LOGIC;
        A_SIMO, B_SIMO, C_SIMO        :    INOUT STD_LOGIC;
        A_CSn, B_CSn, C_CSn    :    INOUT STD_LOGIC;
        en, S    : IN BIT
end bidir_SPI_switch;
architecture behaviour of bidir_SPI_switch is
    process(en,S)
    begin
-- MASTER enable
        if en = '0' then
            A_SCLK                   HOW??
            C_SCLK
        else
-- SELECT either A or B
        end if;
    end process;
    Couldn't make full sense of what was happening. However, it did simulate it well.
    This has been unsuccessful, it seems nothing is going through the switch.
    Is there an example code out there that shows how to build a Bidirectional bus and the assumptions required of the entities that connect to it.
    This is doing me head in.
    In my opinion, the problem is a lack of clarity about the required prerequisites of a bidirectional "switch". A FPGA doesn't offer bidirectional bus switches of analog switch type. It can implement bidirectional buffers, similar e.g. to a 74HC245, that however need a control signal to decide about the actual data direction.
    You have to find out, how this direction information can be deterrmined.
    Thanks FvM, I've added an extra pin in the design for direction and now it works fine in simulation with the bigger design.
