User1584607963412451
6 years agoBGA Ball Missing
Hi Team
We noticed that below mentioned part found BGA Ball Missing. Kindly refer attached physical photo for your checking. Part currently unable to use. Please advise reason.
Part # :...
NurAiman_M_Intel
6 years agoHi,
Also i need to reconfirm, , I could not find the PO# based on the lot code shared below. Can you please reconfirm as we need to check in our system. On top of that, kindly check if you observed any damage on outer, inner, MBB and tray from your shipment. We need to collect information if this is mishandling from distributor.
Aiman
6 years agoHi Aiman
We have received your mail on test log however the image sent cannot be viewed. Please advise if you can send in other format.
PO was placed through Arrow Asia. You may refer to the lot code: S914AF8V0 with DC 1919 for your checking.
CheeHeng Ng
