10 years agobemicromax 10 - sdram CKE pinout needed or not ?
I have a tutorial for the cyclone III for the core commander board which i am trying to translate to the bemicromax 10 . In it .sdram_wire_cke is defined as .sdram_wire_cke ( ...
10 years agoSince it looks like the Bemicromax 10 doesn't have a SD card slot on the board, there won't be any examples using it. I guess I wasn't clear in my previous posting. I'd suggest you try some of the tutorials made for the Bemicromax 10 card. Build them unmodified to make sure you understand how to build projects and load them on the board. These are known good examples that you can use to familiarize yourself with the board. Once you know how the whole Quartus and QSYS process works, you could add a custom QSYS component to connect your SD card.
Without looking at the whole project I can't tell what cke is.
