14 years agoBeMicro SDK
Hi I am using BeMicro SDK and went thourh all NIOS tutorial. Unfortunately I cannot see any tutorial or interface for Ethernet, RAM, and SD-Card. Even pin connection configuration for temper...
14 years ago --- Quote Start --- Hi desh, I've successfully run the web server demo in the SBT for Eclipse which uses both the Ethernet and memory interfaces. The default FPGA configuration has pretty much everything on board except the SD card slot. However I believe that if you want to use the the mobile DDR or SD card in custom designs, you'll need the appropriate IP cores from third party vendors. Hope that helps. --- Quote End --- Hi Skaneta, Thanks for your reply. I am new to FPGA. Can you suggest me which file should i use to get Ethernet or RAM going. Or is there any documentation on getting started. Regards DEsh
