14 years agoBeMicro SDK
Hi I am using BeMicro SDK and went thourh all NIOS tutorial. Unfortunately I cannot see any tutorial or interface for Ethernet, RAM, and SD-Card. Even pin connection configuration for temper...
14 years agoHi desh,
I've successfully run the web server demo in the SBT for Eclipse which uses both the Ethernet and memory interfaces. The default FPGA configuration has pretty much everything on board except the SD card slot. However I believe that if you want to use the the mobile DDR or SD card in custom designs, you'll need the appropriate IP cores from third party vendors. Hope that helps.
