16 years agoBeginner questions on HDL component mapping
Hello, I have a couple of confusing points about component port mapping, which I would really appreciate some explanation on. 1) Do the inputs map to inputs only? Can an output of a comp...
16 years agoYou have to think about signal direction.
you are connecting "someSignal" to an input of LED_FLASHER. Basically 1 clock is connecting to multiple destinations. That is fine. When is not fine is when you try and put lots of different things into 1 signal. Basically, what you are trying to do is this:
_____________
clk------> | LED_FLASHER | --------> led_number1
| |_____________|
| _____________
`---> | LED_FLASHER | --------> led_number2
|_____________|
