12 years agoBeginner device CPLD/FPGA selection for anti-aliasing filter
Hi all, I am working on a HW design for power analysis of 8channel 50/60Hz signals that are sampled @ around 50kHz / channel. These signals needs to be filtered after sampling before transforma...
12 years agoHey FvM,
--- Quote Start --- An economic implementation would e.g. use a 4:1 CIC decimator and a higher order FIR filter for the last decimation stage. In any case, there's a tradeoff between filter transition steepness and required filter complexity. --- Quote End --- I haven't had to implement FIRs at such low frequency. Once you get to having a serial filter, the FIR becomes a RAM with coefficients and a multiplier, or a MACC circuit. Given that 1k-samples of coefficients will fit in an FPGA RAM block easily enough, would you bother adding the complexity of a CIC followed by cleanup FIR? Seems like more trouble than its worth ... --- Quote Start --- Did you notice that audio ADCs respectively codecs have nearly perfect anti-aliasing filters and decimation down to an intended sampling rate, partly even programmable. --- Quote End --- This could be a better solution than using an ADC+FPGA+uC; find an ADC that already includes the digital signal processing you need and interface that to the micro. FvM - Do any particular codec part numbers come to mind? Cheers, Dave
