15 years agoBCD counter vhdl code
I am a newbie quartus user.. please help me thanks http://i54.tinypic.com/2zp2p3p.png This is my written code: library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; e...
15 years agothanks for ur explanation and assist.. understood a lot!
"By slightly increasing the pulse width of load, it should work also in functional simulation." could you explain it more ? how do u increase the pulse width of load. http://i53.tinypic.com/2lbkkrt.png library ieee;use ieee.std_logic_1164.all;
entity d4 is
port (reset, sensor, load :in std_logic;
p :in std_logic_vector (4 downto 0);
led_on :out std_logic;
q :out std_logic_vector (4 downto 0));
end d4;
architecture flow of d4 is
signal count_sig : unsigned (4 downto 0);
begin
process (sensor, reset, load, p)
begin
if (reset = '1') then
count_sig <= "00000";
elsif rising_edge (sensor) then
count_sig <= count_sig + 1;
if (count_sig = 31) then
led_on <= '1';
count_sig <= (others => '0');
else
led_on <= '0';
if (load = '0') then
count_sig <= unsigned(p);
end if;
end if;
end if;
end process;
q <= std_logic_vector (count_sig);
end flow; looking better now. but if (load = '0') then
this code seems useless.. When load is '0' on P=2 .. q is not starting from 2... or when load is '0' on P=20.. q is not starting from 20, like shown in the correct stimulation. please enlighten me. i have been saying countless times of thank you but really i appreciate ur help.. happy lunar new year to all of u!
