14 years agoband pass FIR filter and weird response
Dear all, I have used altera quartus 12.0 FIR II compiler to generate a bandpass filter. The filter uses 11bits coefficients with 17bit data entry and has 80 taps. I put all that into sim...
14 years agoKaz: yes, I've verified this. the impulse response seems to be correct within given 11bits..
FvM: this is interesting comment, but I'm not sure whether I understand your comment. Could you extend it a bit more? My input vector is 16 bits (sorry for my first post where I mistakenly said 17). The filter output vector is 34 bits long (33 downto 0) signed. Hence output 65534 does change 16 lsbs on already 34-bit long 'signed' type. Where did you get 2LSB error? Thanks .d.
