14 years agoband pass FIR filter and weird response
Dear all, I have used altera quartus 12.0 FIR II compiler to generate a bandpass filter. The filter uses 11bits coefficients with 17bit data entry and has 80 taps. I put all that into sim...
14 years agoTry first pass impulse input e.g. [32767 zeros) then you should get the actual coeffs out (though scaled). That way you know its impulse response is correct.
