14 years agoBAD_JTAG_CHAIN again
Dear All, running eclipse-nios2 I try to debug an application. Using ethernetblaster. When I open the Debug Configurations and fill all what is needed, I cannot find the target. Instead it say...
14 years agoOkay guys,
I know the answer: the reason for this is, that eclipse fails to look for the second ethernet blaster because the first one is unable to be scanned. In my command line tools of course it works, because I specify correct cable. In eclipse apparently it does not work because if it fails to scan the first one, it assumes that there is no other server. This is wrong assumption. I file a bug at altera So I removed the broken connection, and everything magically started to work.
