13 years agoBad EPM7064LC68
Greetings to All, In the course of repairing 2 boards, one of the EPM7064LC68 (PLCC) was found to be defective. So the solution is to copy the other good chip and program a new chip. I have ...
13 years agoHi Pete,
Thanks for your reply. I never had any experiences with these type of devices and as you have said, there's a 50/50 chance. I'll contact Terasic and try my luck. Cheers! Nuki --- Quote Start --- The USB Blaster or compatible (terasic makes a $50 compatible device) can program the CPLD's. http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=74 However, how hard/easy it's going to be depends on if the security bit was set when the CPLD was programmed. If it was not, you should be able to read the configuration out, and program it to the new device with no problem. If it was set, you need to have the original programming file, or you are out of luck. Pete --- Quote End ---
