11 years agoBackbone,timing,BLVDS and max speed
Hi all! Iam solving one problem and i need the advice. Iam working on device where will eurocards and this will be hot-swapable. So because of the max frequency od DIN41612 is 557MHz i will ...
11 years ago"Will be able the Cyclone IV comunicate over BLVDS with frequency 350 MHz?"
You might want to first perform signal integrity simulation with IBIS/Hspice models to see if can meet the IO specs. Then run through QII timing analyzer to see if the fmax can meet your target.
