RBash
7 years agoAvalon streaming interface in HLS component can't connect to streams in streaming_dma_afu example.
Hi, I'm trying to use the streaming_dma_afu included in the samples that come with Arria 10 cards, and replace the pattern checker and pattern generator modules with a simple HLS module. I'm using i...
RBash
7 years agoHi,
Yes, the problem was solved by using a sample code for generating AFU using an HLS component.
