10 years agoAvalon st video control data packets format
Hi all, I´m producing video data with the Test Pattern Generator II and moving the video data from avalon st into the fabric to the soc ddr3 with the modular scatter gather DMA (dispatcher and write ...
10 years agoWould be helpfull to see to what address you write exactly and how you fill the missing 8-bit for the 32-Bit or if they just gets filled wit the next subdata. And maybe change the visualisation of the memory content, I guess it is only a visualisation issue and the data is correct. Could you visualize maybe some signalTap-Output?
And keep in mind that only the lower nibble of the bytes holds values while transferring the control packet...
