16 years agoAvalon SPI Operation
In using the Altera SPI core, I have a question regarding the SS_n select line.
In my old design, I was using some 'bit-bang' pots and the addressing scheme to individually select the pots was accomplished using an address decoder, and this worked fine. I am now using some SPI interface pots (specifically the AD5290, 8 bit SPI interface) and I have my SPI core setup in the Master mode. I am still using the external circuitry to perform the selection of the individual pots (i.e. NOT the SS_n line) and I am wondering if this will work correctly with the SPI core’s operation. When I look at the SCLK, the MOSI, and the CS select line, I see the following; 1) The CS line goes active low (control command issued to set lines) 2) Call the alt_avalon_spi_command 3) The correct data appears on the MOSI 4) The SCLK is present and in the correct timing location, and all 8 bits get clocked. 5) There is then a short pause 6) Now the MOSI line drops to zero (no data) 7) The SCLK now clock in the zero data 8) Return from the alt_avalon_spi_command call 9) The CS line goes high I have no idea why the zero data is showing up on the MOSI line, and why it gets clocked into the device. Must I use the SS_n line to control the addressing???? Thanks! Fred1 Reply
I changed the SPI_Read_Length from 1 to 0 and this stopped the read. I also needed to return the strobe line to a 'high' state to correctly select the CS line.
I can now send data to the POT but it is still acting wierd, but I think this is another issue. Have a great weekend. Fred
