15 years agoAvalon OpenCores Ethernet MAC and QII version 10 and higher
Hi, I'm migrating my design to QII 10.1sp1 (after an unsuccessful try with v11.0) and can observe a warning with SOPC builder about the parameter SYS_CLOCK_RATE:CLOCK_DOMAIN that must be of typ...
14 years agoThank you for answering, Fred.
Since I don't use Linux but I directly interface the core with my own driver, I hope I can overcome the problem... if I only could discover where it is! Moreover, in my case it works perfectly with QII V9.0, so I think it's definitely a minor issue, something changed from SOPC to Qsys. So far I could only discover this, by signaltapping the tx_dma module: - 1st packet trasmission: bd_read is pulsed, then pulse on valid_rdata, then pulse on stat_ready ethernet frame correctly transmitted out - 2st packet trasmission: bd_read is pulsed, then pulse on valid_rdata, then rising edge on stat_ready; at this point stat_ready is stuck to a high level until I reset everything ethernet frame is not transmitted I'll appreciate any comment or help
