15 years agoAvalon OpenCores Ethernet MAC and QII version 10 and higher
Hi, I'm migrating my design to QII 10.1sp1 (after an unsuccessful try with v11.0) and can observe a warning with SOPC builder about the parameter SYS_CLOCK_RATE:CLOCK_DOMAIN that must be of typ...
15 years agoThe VISIBLE property of this parameter is set to false. That must explain why you think you don't have such parameter. Have a look to the file (its name is 'eth_ocm_hw.tcl') and you will see what I mean.
However, it seems to be used only to do a 'set_module_assignment' of something called 'embeddedsw.CMacro.SYS_CLOCK_RATE. Because I'm using a Linux/MMU kernel, I don't think this is used and, thus, it doesn't explain this issue. I can add some printk() in the driver to see what's happening, but I can see the RX/TX packets counters growing while the errors counters remain null. That is very strange...
