10 years agoAvalon MM Interface readdata signal [511:0]
Hello, I am trying to read data from the global memory using a pointer. This memory address pointer (64 bits) is an output from my master module and tries to read data from the slave. The...
10 years ago --- Quote Start --- The values stores in global memory are of type integers and performed by the host. When I try to read this data from the global memory the Avalon memory module always reads 512 bits of data from the memory address specified. How do I get the integer data should I be reading the most significant 32 bits of the readdata signal or least significant 32 bits of the data signal? --- Quote End --- You need to read from a 512-bit aligned address, and then extract the 32-bits from wherever you had written them. If you had written them at offset 0 of the 512-bit aligned address, then read them from the 32 LSB's. --- Quote Start --- Also if I store 16 such integers in the global memory from the host then can I read all of them in just one read (also by setting burstcount as 1) ? --- Quote End --- Yes. --- Quote Start --- Now, if I increase the burst count then will I get burstcount*512 bits of data? ie, if burstcount = 4; will I get 4 chunks of 512 bits data. Therefore reading a total of 4*512 bits = 2048 bits (or 64 integers). --- Quote End --- Yes. See Figure 3-8 in https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/manual/mnl_avalon_spec.pdf
