Oliver_I_Sedlacek
Contributor
3 years agoAutostart NIOS from external SDRAM problem
So my NIOS code has outgrown the available on chip RAM and I've moved it to off chip SDRAM. Very slow, but I fire up Eclipse and I can get it to run. I need to get it to run automatically and I've fo...
EBERLAZARE_I_Intel
3 years agoHi,
If there are no error from Quartus/Nios II SBT, you might need to check your configuration in your Quartus design and you MSEL pin of your board.
- Oliver_I_Sedlacek3 years ago
Contributor
Everything, I repeat everything, works except the booting with code in external memory. The FPGA configures, the custom logic works, the NIOS2 runs my code if I debug from Eclipse without trying to boot from external memory. How do I debug why it wont boot? The handbook just gives me a great long sequence of instructions with no guidance on figuring out which step I've done wrong.
