Oliver_I_Sedlacek
Contributor
3 years agoAutostart NIOS from external SDRAM problem
So my NIOS code has outgrown the available on chip RAM and I've moved it to off chip SDRAM. Very slow, but I fire up Eclipse and I can get it to run. I need to get it to run automatically and I've fo...
EBERLAZARE_I_Intel
3 years agoHi,
Any update?
Oliver_I_Sedlacek
Contributor
3 years agoSo two of us worked through it all again very carefully and slowly and got the same symptoms. The NIOS doesn't run and I can't connect to it with the debugger.
Repeating the same experiment and expecting a different result is a sign of madness.
