Oliver_I_Sedlacek
Contributor
3 years agoAutostart NIOS from external SDRAM problem
So my NIOS code has outgrown the available on chip RAM and I've moved it to off chip SDRAM. Very slow, but I fire up Eclipse and I can get it to run. I need to get it to run automatically and I've fo...
EBERLAZARE_I_Intel
3 years agoHi,
The link that I shared have the hardware design for Quartus for you to follow the steps, and shows you the connection that is needed to be made to have it as Reset Vector for Excecute In Place. Maybe you can try the pdf versions and check the 5.2.3.3 Chapter.
