Oliver_I_Sedlacek
Contributor
3 years agoAutostart NIOS from external SDRAM problem
So my NIOS code has outgrown the available on chip RAM and I've moved it to off chip SDRAM. Very slow, but I fire up Eclipse and I can get it to run. I need to get it to run automatically and I've fo...
Oliver_I_Sedlacek
Contributor
3 years agoThe FPGA configures fine from power up (programmed via .JIC as suggested). The problem is the NIOS doesn't boot. I've been following Table 33 and section 5.2.3.4 of the Embedded Design handbook but I'm obviously doing something wrong, but can't diagnose what.
