Oliver_I_Sedlacek
Contributor
3 years agoAutostart NIOS from external SDRAM problem
So my NIOS code has outgrown the available on chip RAM and I've moved it to off chip SDRAM. Very slow, but I fire up Eclipse and I can get it to run. I need to get it to run automatically and I've fo...
EBERLAZARE_I_Intel
3 years agoHi,
You could do the programming using .jic:
https://www.intel.com/content/www/us/en/docs/programmable/683689/current/programming-96050.html
With programming using .jic, you can reset your FPGA device using the reset button or power cycle your hardware and it will run upon power up. Is this what you are trying to achieve?
