Async FIFO size in AVMM interconnect
Hi Fabien,
You can create and edit you own component for _hw.tcl file and have flexibility to control the parameter according to your desires. You cannot edit components installed with the Quartus II software, such as Altera-provided components Refer to link below for creating PD component.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-platform-designer.pdf (p89- Creating Platform Designer Components).
- fvult6 years ago
For the blocks to the left in the above picture (called dma_reader and dma_writer) we wrote our own component _hw.tcl files. Here a snippet of the _hw.tcl file of the dma_writer:
add_interface dma_output avalon start set_interface_property dma_output addressUnits SYMBOLS set_interface_property dma_output associatedClock clk set_interface_property dma_output associatedReset clr set_interface_property dma_output bitsPerSymbol 8 set_interface_property dma_output burstOnBurstBoundariesOnly false set_interface_property dma_output burstcountUnits WORDS set_interface_property dma_output doStreamReads false set_interface_property dma_output doStreamWrites false set_interface_property dma_output holdTime 0 set_interface_property dma_output linewrapBursts false set_interface_property dma_output maximumPendingReadTransactions 0 set_interface_property dma_output maximumPendingWriteTransactions 0 set_interface_property dma_output readLatency 0 set_interface_property dma_output readWaitTime 1 set_interface_property dma_output setupTime 0 set_interface_property dma_output timingUnits Cycles set_interface_property dma_output writeWaitTime 0 set_interface_property dma_output ENABLED true set_interface_property dma_output EXPORT_OF "" set_interface_property dma_output PORT_NAME_MAP "" set_interface_property dma_output CMSIS_SVD_VARIABLES "" set_interface_property dma_output SVD_ADDRESS_GROUP "" add_interface_port dma_output AVMMMWriteDataValid_o write Output 1 add_interface_port dma_output AVMMMWriteData_o writedata Output OUT_DATA_WIDTH_G add_interface_port dma_output AVMMMBurstCount_o burstcount Output 6 add_interface_port dma_output AVMMMAddress_o address Output 64 add_interface_port dma_output AVMMMWaitRequest_i waitrequest Input 1Is there a way to achieve a larger FIFO depth in the automatically generated interconnect by changing the parameters of the components connected to the interconnect? I would like that an entire burst of 32 words fits into the FIFOs.
