11 years agoAsserting DEV_CLRn during configuration
Hi, I would like to know if on Cyclone IV devices DEV_CLRn is held asserted during configuration and beyond the initialization phase if that will cause the registers to remain reset right out o...
11 years agoThanks for the info. The idea is to have some pins forced to hi-Z while reset is asserted; this would be coded into the design file. The problem I have with DEV_OE is that it removes the weak pull-ups when it's asserted and that would let other output pins float.
